Plastic access panel on trans housing?
back to Chicago
Whats it for? Why is it so easy to remove? Mine's leaking on the LX450 I just picked up. Not real bad but it slowly seeping outta there.
That's more commonly referred to as the inspection port cover, and if it has oil seeping out of it, you likely have a rear main seal leaking. Of course, it might not be--oil can also be coming out from under the valve cover, seeping down the engine/transmission join, and *looking* like it's coming out the port cover.
Either way, get it looked at.
Thanks for the info. I will do a more thorough inspection to see where its coming from. I looked at the valve cover gasket and it was not leaking. I'll have to check for the source.
