Placement for OME Suspension Install
Arroyo Grande, CA
Hello All:
I'm on my 3rd Landcruiser (prev FJ62 & 94' FJ80); now upgrading a recently acquired '94 FJ80's suspension to an OME 2" Medium-heavy lift.
Knowing where to place the correct springs and shocks in the correct location is not intuitive for a mechanical retard like myself -- so I'm attaching an image that illustrates what I believe to be the consensus for correct placement for OME shocks and springs on a '94 FJ80. Please correct me if I'm in error.
http://www.axis-analytics.com/tlc/ome_placement.png
Is there a forum image-base where I can upload andl ink to this image?
I'm not an expert but that picture, or the labeling, looks backwards :confused:
It sure looks like they have the "front" and "rear" labels at the wrong ends of the vehicle?
What I am pretty sure of though is that you do the reverse of what you would if you were in Australia since they are RHD vehicles, so going by Australian installation instructions would net you a reversed spring setup.
Bottom line, the longer springs go on the driver's side of the vehicle.
Taller springs go on the left side. So your picture is right if you ignore the frame details.
which end is the front? .... leaf springs? ...that picture is all screwy. 850's go in the front and like Darwood said, taller springs on the driver's side.
Wow...
What changed? Now the picture is "correct" in that the front appears to be the front and the rear the rear unlike when I first checked it...Strange
Good pickup on the leaf springs Leroy. I'm thinking someone at that site has changed the picture around as I don't recall there being leaf springs the first time around.
Picture as it is now for future reference :)
That's not correct. The longer/taller springs go on the longer side of the axles, regardless if it's an US or AUS. The picture got them backwards.
Edit: Darwood comment still stands true on the US trucks, as the yokes are on the right side :)
x a bunch.
The taller spring is designed to counter the leverage of the longer side of the axle.
I have discussed this numerous times with an ARB tech who now has his own business.
:beer:
I fixed the rotated the chassis in the image so it looks right -- I warned you I was a mechanical retard! Thanks guys...
Ah....that makes sense. Didn't realize it was your picture :)
I believe it's also true for all 80 series. The differentials are always on the right side of the vehicle as far as I've ever seen. The confusion comes from OME labeling their springs as driver side and passenger side in some cases, which does vary on the 80 series by location.
