Gents,
I'm trying to get the pitman arm off a Toy truck 2wd powersteering box so I can put it on an Fj80 box.
AFAIK, I'm doing everything right...... Gear Wrench pitman puller, 4lb hammer, breaker bar, lots of penetrating fluid and a propane torch.
I began by soaking the spline in Moovit for a day and over night. Then I tried multiple times to remove it with first heat and the puller. Yep, that puller was cranked tight with the breaker bar. I also kept whacking the 19mm impact socket I had over the puller bolt, hard and many whacks. Nadda. More heat, more whacks, tighten the puller a tad more, still nada......repeat.
I left the puller on overnight, more movvit.......this am, still nadda. WTF?
I tried more of the same for an hour today.
Anyone have any suggestions please?
Thanks.
Thanks.
