piston rings?
wenatchee
I'm looking at buying these piston rings the .010 over OEM PISTON RING SET FJ40/55 E-01/72. will they work with out having to bore the engine? and before I put in any rings I'm going to take a ball honer to the engine.
The only way to know if you have that much wear is to measure the bores, top and bottom and in the middle.
Typically they wear more at the top, the bore will taper in from there, so if you get a good fit at the top of the stroke they'll seize at the bottom.
Plus they dont wear round, but oval.
BORE IT!
The answer is simpler than that.
.010 over rings are for .010 over cylinders (and pistons).
Mark...
Check the pistons that you currently have if that's possible at this point. I've always checked around the skirt 90 degrees off the piston pin for the diameter. This will tell you if the pins that are listed will fit your application.
Have fun!
In a word (as the others have mentioned), No.
Even if the wear just happened to be 0.010 on the cylinder walls it will not be symetrical. Then, just as Mark mentioned, +0.010 rings are made for +0.010 pistons ... not just +0.010 cylinder walls. If the wear is that deep it's time to bore the walls and fit with proper sized pistons.
Not real sure what you are asking. Any quality ring set will work fine for you. In the proper size anyway.
If you just want to put new rings in it, then get rings that are the same size as the pistons/rings/cylinder bore that you have now. You just have to hope that the wear of the bore is small enough that just putting new rings in will do the job. If the wear is more significant, you will have to overbore the cylinder and install larger pistons and rings to match.
Mark...
sometimes, it's just the compression of the rings that wear out and you can fix it by replacing it w/ new (same size) rings, other times, it's your cylinder walls that have worn and you must bore and get oversized pistons and rings.
