Pinion Leak
Hey everyone, I recently replace all the seals, gaskets, and the birf on the passenger side of my '92. First off, thanks to everyone who helped me. It would have been was more expensive without your help. I got it back together okay (with the help of a good buddy who is a mercedes tech ;)), and everything is good to go. However...I have another problem. Actually not so much a problem as minor annoyance. I have a leak now in my pinion seal. Its only a couple drops a day, but it is annoying. I wanted to run something by all of you though. I drained my diff and tore everything apart for my birf and then had to leave for 10 days to see my grandma in Wisconsin. That was already planned so I couldn't skip it over. Now I wonder if the pinion seal maybe dried out while I was gone due to lack of any fluid in there for two weeks or so by the time it was all said and done. It didn't leak before I did the birf job, but now it does ever so slightly. So...what I am wondering is a) if that seal dried out and shrunk a bit while it was free of oil, and b) if that is the case, will it possibly swell back up a bit and stop leaking? I don't know if this is too vague or not, but any experience will be helpful. Also, for you hardliners, I did look in FAQS and search but couldn't find this exact situation. Not saying its not out there, but I couldn't find it. :) Thanks all.
I doubt the seal dried out, if anything I'd say it doesn't like the new oil. Or possibly it did leak before and you didn't notice, or the weather change brought on the leak. But back to the new oil- what did you use? I've heard that using synthetic can help a leaky seal, but it's not reliable info. It's entirely possible that it leaked for the previous owner and they put thicker oil than recommended to stop the leak.
-Spike
The cap type seal, i think you are referring to, that has rubber on it is more of a seal to keep things out than oil in. The part you could be missing is referred to by toyota as the 'slider.'? A metal washer type seal. I had the same problem after a gear swap a few years ago.
Sound familiar?
Just curious. But how much did this cost? I am looking at doing this sometime before this Fall. I hope anyway.
Yeah, and what is involved in replacing it? I am not an extremely adept mechanic...: ). But I can work my was around. As to Spikes question, I used 80-90W Lucas Oil in there. I don't think the previous owner used that as I can smell it now, and before there was not a smell that I noticed. I can smell it from the leak, but it also leaked out the other birf that I have not replaced the seals on yet. So, they probably used different oil. Any suggestions?
Okay, I did some searching today. I went to our local farmer supply type store, atwoods and looked at different Gear Oils. They had Rotella in 85W-90, and then the rest was mostly there generic brand they use called "Mystik." They had that in the same 85W-90 as the Rotella. The same weight I have in there, except its Lucas now. Then they also had the Mystik in 85W-140...is that too thick? I'm not sure was was in before but it was heavier than the lucas I put in now that I think back on draining it. Anyway, anyone used 85W-140 in there front axle or is that too thick? And this would just be till I get the leak taken care of properly or switch back to 90 weight in the winter. Let me know, thanks.
Mystik motor oil used to be popular with the farmers around where I lived about 20 years ago. I am not sure about the status now. 140W oil is what is used in the axles of large trucks, i.e. Mack etc. I personally wouldn't put it in a smaller vehicle.
I doubt anyone here is going to tell you that putting thick oil in the diff is a 'good idea'. It might not cause any damage, but no one wants to feel responsible for your diff if it does. You would be better off going to a site like www.bobistheoilguy.com and asking their opinion on thicker oil, and perhaps synthetics fixing leaks, and even 'stop leak' type products. If you want the very best thing to do, the advice is to fix the leak by replacing the seal. If it's not a fast leak, you could ignore it for a while and check the level occasionally, until you have a chance to get it fixed.
-Spike
