Pictures of boost install 1kzte
Maui Hawaii
looking for pictures of where to install the boost sensor for my glow shift gauge. It’s not a vacuum install. Not sure where to put the sensor.
I installed mine into a brass T with 2 barb fittings. Plumbed in between the filter and sensor. Been like this for the past 3 years.
Where did you get those parts from ? what exactly do I need to? That's awesome !!!
Replied to your DM but figured I’d share here too in case someone else comes across this in the future.
I got mine from Amazon, couldn’t find exactly what I needed at my local hardware store. . A brass tee and some barb fittings. You’ll also most likely need a longer 3mm vacuum line to plumb it all together, OEM Toyota line is part# 90999-92002 but any 3mm vacuum line should work. And don’t forget some teflon tape or other thread sealant.
https://www.amazon.com/dp/B08LVQLV3V?ref=cm_sw_r_cso_cp_apin_dp_F5TND0CFP5EHB29CJJYH&ref_=cm_sw_r_cso_cp_apin_dp_F5TND0CFP5EHB29CJJYH&social_share=cm_sw_r_cso_cp_apin_dp_F5TND0CFP5EHB29CJJYH&titleSource=true
https://www.amazon.com/dp/B087Q9GV23?ref=cm_sw_r_cso_cp_apin_dp_NP1GEXPJFNY388VX31VS&ref_=cm_sw_r_cso_cp_apin_dp_NP1GEXPJFNY388VX31VS&social_share=cm_sw_r_cso_cp_apin_dp_NP1GEXPJFNY388VX31VS&titleSource=true
Once you have the Tee all assembled and the glow shift boost sensor installed. You’ll put it inline between the boost filter and the turbo pressure sensor.
