Pickup Rear axle payload / GVWR / GAWR ratings, Hilux, Tacoma, T-100
Anchorage Alaska
I also have this up in the pre 95 section but not having much luck, so probably better to post it in this section.
Link for other section: https://forum.ih8mud.com/79-95-toyo...ayload-gvwr-ratings-hilux-tacoma-t-100-a.html
Looking for info/data on payload / GVWR, and GAWR axle ratings for the hilux trucks, tacomas, and T-100's.
Specifically for the 96-04 Tacoma.
Might be better to post in the other thread but here is ok too.
Thanks.
My 04 Tacoma has RR GAWR 2800lbs and the GVWR is 5100lbs
Thanks for the info.
Just to make sure, this is the generation one Tacoma 96-04 correct. Still the mini truck model and not the current mid size model right.
I could use the GAWR front numbers too when you get a chance, trying to build a database on it.
