- Location
- United States
Anyone have one the want to sell, ideally with the electrical plug as well?
It’s not the photoman bracket but there is a seller on EBay selling similar with the plug. I bought one but never installed it, it’s good quality.Anyone have one the want to sell, ideally with the electrical plug as well?
Thanks!, yeah I saw that one as well. Decided to purchase it as I need a alternator replaced.It’s not the photoman bracket but there is a seller on EBay selling similar with the plug. I bought one but never installed it, it’s good quality.
Have you installed yours yet? My alternators on the way out and Joey said his won’t be available for a few months.Thanks!, yeah I saw that one as well. Decided to purchase it as I need a alternator replaced.
No I have not, a couple issues with this bracket.Have you installed yours yet? My alternators on the way out and Joey said his won’t be available for a few months.
1. The new 150A Sequoia alternator has a larger upper hole than the factory one which means the factory bolt is loose in the hole and it has no bushing. I tried to remove the bushing to the new alternator from the old one but it won't fit.
2. The lower bolt hole on the factory unit is tapped for like a 8x1.25mm bolt, the Sequoia one has a 10mm hole so once again it will require a larger bolt and nut to make this work.
So I was at work and did not have access to all of my tools or hardware so possibly this bracket could be made to work but not as it's supplied and not with the Sequoia 150A alternator as is. I bought this bracket and like 2 weeks later Wits End announced that they would be making brackets again which seems like it will make the above issues go away.
Yeah the wits end kit should be solid. I had messaged Joey about it but it seems it’s going to be a few months out. I’m thinking I’ll just go with the Jag alternator if I can find a denso alternator like some people have.No I have not, a couple issues with this bracket.
I have a bracket, plug adapter, pulley and reman denso 150a alternator I would sell if you are still looking.Bump to see if anybody has one by chance.
Just messaged you. Thanks man!I have a bracket, plug adapter, pulley and reman denso 150a alternator I would sell if you are still looking.
