PHH replaced (whew!)
Hurst, Texas
Even though I had absolutely no 'seepage' from or around the nasty PHH, with fourteen years and [only] 135,000 miles, I was getting a bit apprehensive about the PHH... especially since we have ordered a little 17' Casita travel trailer and will be going goodness-knows-where starting this summer.
One l*o*n*g look up 'under there' and I knew this was a job that I would really like to be done by somebody who had done it before! I did a bit of 'asking around' and wound up taking it to a shop here in the Fort Worth/Dallas area.
Well, I must say thtat I am super-pleased. Not only did he do a great job (installing the Samco blue-hose kit that I purchased from a Mud member), he went 'above and beyond' what I expected.:clap:
Since I'm not sure about 'Forum Rules' I won't post the shop's name but will be glad to do so in a PM.
If you live in the Fort Worth/Mid-Cities area this is a great place for Cruiser work.
All the best,
Rob
Well! I never! Someone paying a professional to do work on their Cruiser!? You have got some nerve!
But seriously, thanks for not being beholden to the prevalent owner-must-do-all-work-at-all-costs mentality.
Thanks, deanf ! I thought that it was a more-than-fair deal: under two-hundred bucks (total, out the door price) to replace both the PHH and the also well-hidden fuel filter.
Rob
its a nice comfort to know its been done and out of the way. Awhile back when mine went out I happened to just be reading about the PHH here on 'mud. 5 days later mine went LOL, I knew exactly what happened when it did.
Rob
How many hours did it take them? I betcha if you went back in there they wouldn't charge under $300 to do 'em both. ;)
You have absolutely no idea how much fun you missed by not doing it yourself. It is a life changing experience.:p
Yeah, milehigh, I've got a pretty darned good idea... I actually dug around in there for a while, straining like crazy to get a 'hold' :wrench: on that lower bolt (awful :bang: ). Then good judgment kicked in (quite uincharacteristic for me!) and I decided to let my local shop do the dirty work! Good move...
Rob
By all means, If you have the money or do not have the time, have someone do it. Just make sure they know what they are working on is not a normal vehicle.
Some shops have really messed up Cruisers because they did not know what they were doing.
The most frustrating PM item I've performed thus far. The old one came off easily enough with a Dremel but I had a rough time persuading the new silicone hose to snap onto the block nipple. Walking away when I got frustrated was key for me. Felt great to finally get the new one on there, even though the old one looked really good inside once I cut it open. Oh well, it's done. ;)
OK I just finished the PHH and fuel filter while doing a marathon (still working on the front axle)....and not that bad:flipoff2:. I am sorry if I offend anyone, but with all the build up...I was kind of let down. The fuel filter was more of a PITA than the PHH. However, I did remove the brake hardline, AT dipstick tube, as well as the starter. I already had the brakelines totally bled because I was doing a caliper rebuild. Might sound drastic, but just a few bolts to remove these parts and the job is cake.
Probably not worth bleeding the system to get that brake hardline out of the way, but if you are doing the brakes, this would be a great time to do the PHH and the fuel filter. Cost: $50 parts (OEM fuel filter, blue silicone hose from local trucking supply and constant tension clamps from McMaster-Carr)
Apples to oranges...the more parts you can remove to get to it, the easier it will be, no doubt. I left the brake line, starter and driver's side wheel in place. There is no wrong way to do it however. If you get it done and it doesn't leak (or start leaking later), you've succeeded. ;) I do need to look at my fuel filter sometime...
