PHH...Maybe???
SLC - Utah
Ok... This is definitely not the way I wanted to intro myself... I have 2 Cruisers right now... a 100 for the princess and an 80 that someday will grow up.. :)
The 80 is a 40th with 165k, 3x locked and still as stock as you can get... Having 2 cruisers doesn't leave a lot of money for mods..
Yesterday morning I started up the 80 drove it around the property a bit then came back and parked it... then I heard the trickling noise of something dripping on the concrete... not good... at first glance all I can see is this massive dripping from around the transmission... right at the pan gasket... only thing is.. the color is green/yellow...It was pretty cold so the heater was on... I slid the temp lever back to 65 and it looked to slow the flow a little, checked the interior on passenger side for any dampness and I tried looking from top down at the back of the motor but couldn't get a view of where the coolant was coming from, I only know that coolant is leaking, heavily, and it is running down onto the tranny on the driver side... I tried to look for the location of where the PHH is, but between the late nights at my office and the remodel of the house... this was just a straw breaking the camel's back... any way, flame me if I didn't search hard enough, and if the "Cruiser Gods" will, please shed some light on my problem...
B
Just changed the sig line... my bad...
Sounds like a PHH leak (key words=coolant, dripping after stopping, LH side by transmission.)
Could be up at the heater control valve at rear of engine, center of firewall. There are several heater hoses plus the PHH goes up to there via a metal pipe.
-B-
Thanks Beo... I couldn't find a pic that would give me a good look at where the PHH is... Do you know where one is right off hand?
Ok... nevermind... checked slee's site... as per another post and... well there were the pics I was looking for... let the initiation begin...
You already found the pics; if you look through the DS wheel well above the starter (against the block) you should be able to see it with a bright flashlight or worklight; at least you should see the leakage and characteristic old antifreeze stain/crust.
