PHH is done. Alignment Question...
Columbia, MO
Old one came off easier than I was expecting which I thought would be the toughest part of the job. Dremel made short work of the cotter-pin clamp and a pair of vice-grips grabbed the second one nicely. Old hose looked really good actually.
My biggest trouble was installing the new one. I finally got it on there but it is offset a little bit. Could not get the hard tube to line-up perfectly with the block nipple. No doubt I tweaked things a bit. Pictures below for your opinion. The vertical hard tube is bulging the side of the silicone tube a little bit. I want it done correctly and will try to fix it if you feel I should.
So...
1) How much offset is acceptable with the silicone hose?
2) How tight do I snug down the 8mm clamps?
Thanks,
Mark
If it doesn't leak the tweak is cosmetic. You don't want to break something else trying to tweak it back.
x2, looks fine IMO.
Did you remove any of the nuts holding the metal pipe during the install? Could the miss alignment happen then?
Removed the top bracket bolt. Tried to remove the lower bolt but even with a flex-head wrench, I could not get to it from above or below. I'd like to know how people get to that one. Really I would! :) Removed the transmission dipstick and zip-tied the brake line bracket out of the way. This job kicked my rear as expected.
Sounds good...I'll button everything back up tonight and check for leaks.
Looks just like mine after I got done, and I have had no problems.:cheers:
Took it on a 50-mile drive. No leaks. :)
