PHH Change Up
Central Florida Swamp
Anyone ever consider or actually bypass the metal tube that the PHH connects to and simply run a longer piece of hose from the lower nipple up to the upper connection. You could use the metal tube as support for the new hose using metal ties or similar. It might be easier than messing with loosening the tube bracket and in the end you would have 1 hose and 2 clamps instead of 2 hoses and 4 clamps. It would make for a easier field fix too. I havent looked at the clearance along side the metal tube yet, so if there is none, this idea would be shot down. Comments welcome.
A few people have done just that. A lot of people carry a length of heater hose just in case the PHH gives out to make change out easier on the trail.
Search for PHH and you will find thread after thread of remedies, cures and how-to instructions.
Riley
If you go that route, suggest you consider a grade of hose better than the cheap stuff you find at most autoparts stores. Check out Gates website and search for heater hose; they make at least three types in the size you need. Green Stripe, Silicone 2-ply, and Silicone 4-5 ply. The last one is indestructable, but it also is stiff as a board and will not take any bends, so that is really out. The general use silicone can stand up to more internal temperature, but is more likely to pop off anything you put it on and you must use constant torque clamps; silicone also abrades more easily than rubber. Silicone also weeps directly through the wall a bit, no matter what you do. Summary; if you use the by-pass trick, Gates Green Stripe, possibly with some type of external protection from heat and abrasion, like a heat wrap sock, tube, etc.
On the other hand, why not do it right, and use the Gates Green Stripe or Silicone heater hose for the short section of PHH. Just be sure to use constant torque clamps if using silicone hose, NAPA carries them(made by Gates), about $3-4 each depending on your discount.
Dusty has done this and I have done this. I used the Napa equivalent of Gates Green Stripe (Gates manufactures it for them) and wrapped it in heat tape. I have spare section, pre-wrapped, in the back of the truck. No problems so far. The hose arcs up between the intake and the brake booster--it does not follow the old metal pipe line.
I wrestled with the PHH for probably 4-5 hours before ripping the metal pipe off and using a single hose.
Search Dusty's user name and mine and PHH and you'll find some stuff.
Good luck!
Thanks Guys for the info.
Mr. Gray- I've never heard of silicone weeping thru the wall. Does that mean the liquid it carries soaks thru. I cant imagine that being a good thing for automotive applcations. SAMCO makes kits of silicone hose kits for a variety of race/performance cars and they seem to advertise they are the best. Running gas or oil thru silicone would be dangerous if it wept out- can catch on fire.
Maybe the green strip long hose bypass is the way to go- cheaper, more flexible, and dont need torque clamps. Do you really think the heat shield wrap is needed considering the OEM 3" peice doesnt have it. Or is it just extra piece of mind?
The heat tape is mainly peace of mind for me. The intake doesn't get super hot but the tape also helps protect against abrasion if the hose does rub on something. Cheap protection (but I got the tape free).
Did you find any/all the pics you needed? If not, I could try to take one or two.
Lugboot,
Dont think I need any pics unless you have easy access to them. I have seen several pics on the lower nipple and metal tube and have a bud that has replaced his 2x. He actually gave up on trying to loosen the lower bracket bolt and just broke it off at the tab-weld. Now he relies on the upper bolt only to hold that metal tube stiff, which is probably enough.
What kind of tape did you use? A metal backed tape?
It was a fiberglass electrical tape used in industrial motors, good to 800 degrees.
I checked--no pics handy, i'd have to take them.
I will never change the PHH again. Never. I will either sell the truck or bypass the stupid freaking pipe like others on this forum -- but I'm not fighting that stupid little piece of hose again. F#cking PHH.
