Pertronix help
Mentone, Cali
Ok, so yesterday I installed a pertronix kit (Ignitor II and Flamethrower II).
Ran the '40 today and noticed a 'studder' when I was accelerating in first gear. I think that part might have to do with the '40 not being ran for 24h, and I didn't let it warm up at all. I did notice that after it was warmer, it seem to run fine, but a lack of acceleration in 3rd, not a whole lot, but noticeable, it did make a pop noise once, but not as loud as a backfire.
I was doing some research here and I've read that some people say to change the timing (I haven't verified the timing yet), and change the spark plug gap.
I'm looking for some tips with electronic ignition, and what I should look for, I thought about changing back to the stock coil, but I haven't yet.
The motor is a '65, if that helps.
Id keep with the electronic ignition , keep points in the truck just in case , yes ur sapposed to run better leads ( copper core if u can tolerate stereo noise lol ) & open plugs wider , look up the manufacturer site for info .i"d reset the timing as may be different to here the points opened/closed , hence the stumble , if installd correctly , it should be smoother, start quicker , be, dwell angle be more reliable,etc
Thanks for the info. I haven't messed with the timing yet, I'll check that tomorrow. I put the stock coil back in, and ran it for a hot lap, seemed to be OK. I would like to get it dialed in though so it runs better.
If you have everything installed correctly and your timing is right, you are better off going with the Pertronix coil than stock. Check the Petronix web site for the directions to make sure you installed everthing correctly. Also, my recollection is if you have solid core ignition wires, they are not compatible with this set-up. I installed the exact same thing you did in my '74 and there was a noticeable improvement in ignition performance.
get it timed, and you wont look back..... I didn't
I'm going to time it when I get home, I have read that the timing window is over by the starter, is there an easy way to read what the timing is it? I know on my other projects, the timing numbers can be seen on the crank pulley.
Update - Checked the timing just a few min ago, and honestly, I don't know if it's off or not. For some reason my timing light isn't flashing very fast on cylinder 1, but it flashes a lot faster on cylinder 2.
I could *kinda* see the BB, and it looked like it was right on the needle, so I'm not sure if that is right or not.
If your timing light is not flashing on #1, that's the first thing to fix.
How the distributor cap and rotor? Plug wires? Plugs?
The timing light flashes on #1, but not as fast as it does on #2. I'm going to change out the cap and rotor shortly, and see if that does anything to help.
If the BB is showing at the mark, you're at 7* BTDC...factory setting. Find your spark problem out before you start trying to adjust your timing...
I figured the spark out, distro cap and rotor was toast. I hooked up the timing light and didn't even see the BB. Started to advance the dizzy till I saw the BB.
I moved the dizzy till the BB was about 2 BB lengths away, so I advanced it.
I also changed the spark plugs, gapped them to .040 and test drove it.
Seems to run MUCH better then before. My guess after I checked the timing is that it was way off, too much retard, for the lack of a better word.
Interesting reading. I was under impression that timing would stay as with points. Seems it need to be adjusted accordingly. But after adjustments what the point to keep the points in the vehicle as a backup if you can't use them without adjustment of the timing back?
If your pertronix were to die out on the road, which is highly unlikely, you could throw in the points and set the gap with a matchbook. Your truck would start and probably run fine. You could even time it by ear, advancing it until it starts to ping when you drive it, then backing it off. It's way better than being dead on the road.
Exactly. It will get you home from the trail, it's only really a fail safe, but the odds of the pertronix failing is slim.
hey hows it going IM intersted in the kit you got pertronix kit (Ignitor II and Flamethrower II). i have a 72 fj55 with a 1f motor would the same kit work with mine and whats the part numbers you used thanks for any reply
