Perplexing brake problem that is killing me
MN
96 LX 450. I have problems with intermittent brake sticking. Have replaced all rotors and callipers and bearings. Replaced flex hoses on front. Replaced fluids. It is always one of the front tires, usually driver side. Randomly the caliper will stick on one side (have replaced callipers twice in case they were faulty). When I replaced the flex hoses it stopped happening for a little over a week and then started again. Changed fluids in case there were contaminants. Same thing, it stopped for a while. Last thing I tried is the linkage under the dash above the brake pedal. That worked for a while, happened again, adjusted, worked for a while and now it is doing it again. I don't feel it's the master because it only happens to one tire at a time. Any ideas? At this point I am ready to get rid of it if I can't figure it out.
The axle to frame hoses and the axle to caliper hoses? (4 total)
and three more in the back..ZZ top reference (sry)... but its true there are three more flex lines on the rear.
According to the FMS for Brake drag you've covered everything except:
Booster push-rod adjustment
Vacuum leaks for booster system
and Faulty Master cylinder.
But only happening to one side at a time is very odd, one would think that if it was any of the above, you would get brake drag on all four corners.
Could be an ABS valve hanging up...
Wheel bearing adjustment. Are they torqued to 30-35 LB-FT?
