Permatex Gasket Maker
Manitouwadge, ON
The bolts have seemed to rattle off the bung for the O2 Sensor and the gasket is toast. Just wondering if anyone has used the Permatex Ultra Copper Gasket stuff even as a temporary fix until I can get the proper gaskets.
The package says sensor safe and the would be my biggest concern. Why don't you just go to your local Toyota Dealer (if ther is one within range) and get the proper gasket. They are not very expensive, and you wont have a mess to clean up when you get the proper gasket.
If you have an auto parts store nearby, get some high-temp gasket maker and pound one out yourself.
Cut a rough size larger than the gasket will be and hold it up to the surface where it will go. Use the ball end of a ball peen hammer and gently pound it against the gasket until it cuts out a perfect shape.
I wouldn't use permatex on the exhaust system, it'd be very messy and likely wouldn't last long but I have no experience doing that. Someone will undoubtedly post that they did it and it's lasted for 150,000 miles !
g'luck with that. Dan.
