Peesalot / cutsalot
here
For 39.5 x 15.5 on 15x10 rims ,
what would the best WB for a FJ40 SOA , SR , saginaw ?
plan on cutting rear fenders at inner fenderline just straight back and moving rear back , and removing under seat tank and getting custom cell ( 24 gal.)
I will pull 1 leaf from the alcan's( 2 nd. shortest )
build custom box under seat to hold spare parts ( lots of room for all of em.)
Am 94 in. WB now and would like to know what you girls think ?
Does 102 " look stupid on a FJ40 ?
John-
Mine is 101". I have the Butch Lewis PS kit on mine though, which boxes the frame and stretches the front out a few inches- maybe 3? My front springs are flipped so the military wrap is in the front, and puts the spring pin further forward, and the hanger is at the end of the boxed frame. Then I am running stocker 55 springs in the rear. My axle is sitting in the middle of the rear springs (middle of spring pin front and rear). Offsetting the axles on the spring pins will easily give you 102 - 103" depending on 1 or both axles offset. Check Manny's pics from last weekend if youre interrested in pics. 102" wouldnt be much of a difference from mine, but I would look to pull your front spring hangers forward if you can.
I dont remember what you have in the front. If its not boxed, boxing it and moving your hanger forward will help even the length out, instead of having your rear axle hang waaay out the back.
With 39's, you'll deffinitely need to cut some sheet metal front and rear. I guess get some of the bling metaltech fenders for the front and move them up higher toward the hood would help. Otherwise youre looking at some big ass bump stops!
SOA, 350, and lots of other bits and pieces has left little money for the rest of the project, like my 37's.. so heres the rig, uncut, with wee little 33's on it for now...
cheers!
Dustin
