Hello to all from a Newbie and thanks to the forum for all the excellent help and advice already received. I need some thoughts on my HG.
My ride is an LX450 with 300,000 k on her and she has been well maintained, with regular tunes , oil changes and coollant flush. Over the last 2 years since discovering this excellent resource i have baselined the truck including front axle service, rebuilt powersteering pump and replaced the steering box, a scan gauge rides on the steering column. For Mods I have a 2.5 inch OME med lift with Blue slee caster correction and Landtank alignment temlpates, 285 geolanders have served well. A rear Kaymar carries the spare to keep me from crawling under in the deep snow or muddy mountain roads of south east BC where I live.
So here is the problem, I have never had a hint of por running on theengine although a few oil leaks need some attention. However after a recent ( 20 km ago) VERY cold morning (-35c) start up I felt like there was something amiss, when I got to work I checked the oil and while it was full there was a small amount of foam on the dipstick, checking under the cap showed a thin coating of foam as well. I dropped the oil that evening and there was a small amount of curdled foam in the pan maybe 3 tbsp full. Since the change and a little warmer temps the truck has run fine but today there is a very thin coating of foam, more like a misting of foam on the underside of the cap. I have already ordered the HG grind kit from Cdan and the DVD from idahodoug. Is there any chance this is something else? it is not the best weather t be working on the truck over the next 30 to 90 days. i was going to head to calgary and back (500k) but will not drive it if the experts advise against.
Again thanks to all, so far I have been able to find everything I need thru search, but was hoping for confirmation from the board
Thanks and merry christmas.
Peter
Peter
