PCV Changed....
so when i removed my PCV valve i ended up tearing the end of the rubber hose....
the fix... wraped it with electrical tape.... untill i can buy a hose clamp to attach... think thast ok???
On the second hand... what the heck does the PCV even do? I can change it, but i have no f'n clue why i changed it, or what this valve does....
Someone educate me with some mechanical wisdom please
It's fine, as long as the hose reaches.
PCV = Positive Crankcase Ventilation
It's an emissions control device. What happens is gases build up inside the crankcase, and there needs to be a way to get them out. The PCV valve lets those gases out from the engine, usually through the valve cover, and back into the intake where they can be burned again.
