Patching a hole with beadlock rim
Temecula
I have beadlocks and ran over something making a hole in the tire. I have never taken apart beadlock rims. If I take apart the outer beadlock rim will I be able to reach in the tire to patch it/ plug it?
Well although I'm no expert on beadlocks, aren't they just steel circles that get bolted to an existing rim? Pretty sure in order to get a patch on you still need to remove the beadlock AND still break the bead to get the tire off the wheel to get the patch on.
To my understanding, beadlocks use two steel rings on one side; one ring that is welded to the wheel, and another ring that is bolted on top of the first ring. The bead is pinched between the two rings, essentially "locking" it to the wheel. Hence the name "bead-lock".
IOW, you should be able to get inside the tire. Just make sure you let the air out first. :hillbilly:
Make sense?
Real ones. Im going to attempt it and see what happens.
You will want to remove the rings on both sides and remove the tire completely. Unless the wheel is super narrow, and the tire is very flexy, you will have a tough time working on it with one ring still attached.
