I know there's a kit to relocate the driver's seat back a couple of inches, but is there a similar kit for the passenger seat? I have a 78 FJ40 with the gas tank under the passenger seat.
No kit for that so far as I know but it's possible to do it by making extension pieces for the front bolts and turning the rear brackets that bolt to the floor around. You can get a little under 2". (think it was actually 1 7/8"). The fillerpipe and fuel vapor recovery setup limit how far the seat can be set back.
My RHD BJ40 has the tank under the driver seat and I'm 6'3". Moving the seat back lets me use the high clutch pedal without banging my knee. The extensions for the front are just 1" x 1/4" bar stock about 3" long with holes for the seat behind holes for the existing bracket. They sit on the bracket, under the seat rail.
Pretty simple. Noticable if looked for,
Just look at it for a while - you'll see what's needed.
I bought that extension kit for my '78 40 a couple years ago and realized I'd have a more stable platform by simply moving the triangular pedestal under the driver's seat back a couple inches to match the distance of reversing the rear brackets. (Then I drilled new holes further back on the console side of the driver's seat mount.)
Gregor said:
Anyone know why it wouldn't work for FJ40 passenger seat?
Is it because you can't turn the rear brackets?
The passenger seat rear brackets are a different size from the driver's, and reversing them is going to give you a different distance that may not match up with that kit. (Easier and cheaper to fab something yourself.)
Plus, like Honk said, you also got all the filler pipe / vapor recovery array to contend with.
I reversed the rear brackets on my 78 without any problems of clearance with the evap system. The left front bracket on the pass seat slides back where just one bolt fits. The right bracket needs to be extended by a plate. ONe bolt will work but there is too much leverage on the bracket center and it will bend.
