Please specify year of truck and whether it is a locked or unlocked truck.
Thanks.
PS: Last pic: drive flange: 43421-60040/60022 depending if you have an earlier birfield or a later one.
-o-
Its a 93 LC and i believe it does have looks
Also are we looking at the front diff or the rear?
Isnt the first picture a part of the transfer ?
You can verify your truck has lockers by confirming there is a dial to the left of the steering wheel that says DIFF LOCK.
Slee - Differential Lock Switch (Toyota 80 Series Land Cruiser)
It sounds like you are doing a complete front axle rebuild and the FAQ on this site has step-by-step instructions that you, and your mechanic, will find helpful.
i believe so, i need the center piece on both sides of this part... i'm having my pinion bearing replaced and my mech found a few other issues, both inner axles need to be replace and birfields as well.. i believe the inner axles mount into the 1st and 2nd pic
You need to better identify the parts that your mechanic wants to replace in the front diff. You can use MS Paint to annotate the images.
That 2nd part is a drive flange and it is the "short" flange found on 93-94. Call American Toyota to purchase your parts.
-B-
I'm 99% sure he is talking about the carrier bearings.
Anyway, based on this assumption, here are your part numbers:
Drive flange: 43421-60022
Carrier bearings: 90366-50007/90366-75001 (1 each)
We have all three parts in stock.![]()
Thanks are u sure its the carrie bearing becuase a pic is listed below of the carrier bearing it does'nt have any groves in it like the pic above.....
Again, I am not sure unless you do some Photoshopping or use MS Paint and show me exactly what part you are working on or exactly what part you need. There are a lot of parts in your picture--all of them sourceable and replaceable.
Thanks.
-onur
The parts i need are circle in yellow!!!
What is the story on this truck.
New front diff assembly needed.... new pinion bearing needed.... 2 new birfields needed... 2 new inner axles needed... 2 new drive flanges needed.
Was this thing damaged in an accident? We rarely see this much damage due to wear or even neglect.
-B-
