Parting out '83 FJ60 - Denver CO
Hey treeroot, you said the axles are goin under your 40. I'm a little confused, are you talkin about the whole axle or just the innerds so you can have disk brakes. If so that is cool, what do you have to do to make the conversion. I've got a 40 with all drum brakes and have been lookin at puttin on disk brakes as cost effectivly as possible. Thanks for the info, you can send me a pm to make it easier.
Chuck
Hub-cap
Do you have a (1) GOOD hubcap? Cheap?
Chris
The front spring perches need to be outboarded because of the extra width. I'll have a write-up on it shortly, probably after Moab.
Hub caps already shipped to Landpimp.
I'd be interested in the whole power-steering set-up if Dan_J-spec_fj62 doesn't end up getting it.
What condition is it in (ie. milage, leakage etc). PS box, pump, pump bracket, pitman, steering shaft, steering column, crank pulley, hoses).
Prices?
Cheers,
Steve
smcruisin@hotmail.com
Rear panels in cargo area? Plastic dash piece around all knobs and below radio. Commonly is cracked or broken as it is brittle.
The panel around the knobs is gone, I'll check the rear panels....
Power steering might be sold.... Jeff or Paul...
The front CV will be pulled soon, it is still trapped under the truck (sold) name escapes me but I have it in an email...
I am going to test the ABV tomorrow (sold) NocalFJ60
Webster needed some interior parts...have to check email...
Please post if I forgot anyone
Treeroot-I missed you at Cruise Moab. Would sell the transfer case output flanges front and rear? Let me know.
Thanks.
I met most of the folks over in the Cali 80s section...what rig were you driving?
I think I am still going to keep the t-case for the LV project.
rear locking mechinism
I Need A Reat Striker/lockin Portin Of The StriKer That Is Housed In The Window Side Of The Rear DooRs. It Is Not Acctually The Lock, But The Part That Keeps It Shut When You Close It.
How's about a drivers door window regulator to 97702
Ridiculous, but I need the little plastic catch that secures the rod that holds the hood open. Mine broke after only 17 years!
Please PM me if you have one for me.
Mike
