Part time question.
Angier, North Carolina
Ok so my 80 is part time converted and I'm having a huge issue with one of my manual locking hubs, to the point where I can't use any of the hub parts on the passenger side.
Of course this is my DD and I need to get it back on the road now.
Can I use the factory hub body to get her back on the road? The only issue that I should run into is not being able to have 4x4 correct?
Also, having it set up this way temporarily still wouldn't rotate the birfs etc because the VC is gone correct?
Thanks guys!!
What is the issue you are running into, perhaps we can help you resolve it.
As far as running drive flanges with the xfer case part timed, yes you can, however it is going to make your front axles and driveshaft rotate, as you drive along in 2wd, but the front won't be under load...just being driven by the road turning the wheels.
The hub body flange cracked and I need to replace it. :/
If that's the case, I should probably lock the other hub so they're equal right?
yes definately lock both hubs, if you don't your front diff will be doing a LOT of differentiating!!!
Which hubs did you have? Aisin? or the Brazilian AVM's
I had the AVM's also, and the little torx screws seized in the hub and snapped off. I had to cut the hub of...all it took was a screwdriver and hammer to cut it...not a very strong body at all. I replaced with AISIN hubs, much much better quality.
I grew up in New England so I nevasieze the hell out of every bolt, second nature. So not too worried about that, but they did look weak.
Even so, unfortunately switching to the asin's right now isn't in the cards(wish it was) right now.
Really hoping that the AVM hub gets warrantied out as it has zero miles on it. It cracked while I was installing it and my tq wrench never clicked off at 26#. Leading me to believe it's a bad casting defect. The other side installed without issue.
You sure theres no burrs on the alignment dowels and the hub was jamming on them? Would explain why it cracked in two spots. Very unusual regardless of the casting strength to crack there. Make sure its sitting flush with the hub first before tightening the nuts.
Yeah man, sucks. Just bought the truck and immediately installed 4-new shocks, all 4 pads/rotors, both knuckles rebuilt, plugs/wires, part time kit, radio, CB, yota teq antenna mount, alpine deck, 3D printed cup holders(forget the guy's name).. All new fluids.
Basically doing the updated maintenance and then to have this happen really sucks. Especially right before I drive to MA, from CO on May 4th, now with minimal time to work out any bugs on the truck.
Yup it was on there flush. Along with brand new hub studs and cone washers from Toyota
Alrighty to add closure to this thread.
Slee offroad swapped out the hub body for me and I got the new one installed and it's good to go without issue.
***But on a seperate note, I measured the factory hub flange and AVM hub body flange.
Well the factory measures out to: 0.40"
And the AVM hub body flange measured out to: 0.32"
The thinner hub body flange brings the nut very close to the smooth shank of the hub stud which could cause the stud to strip out and or not allow you to get the nut tq'd to 26'# and I would almost suggest running 2-flat washers to avoid this from occurring.
Cheers.
