Part time 4wd
The only real info I have been able to find is a claim of about 2-3mpg increase in mileage. So if the total cost of the kit installed is $1000, it would take 30K miles at $3/gal to make up the difference in cost. Benefits would be less wear on the front drive train which may make up some of that cost. Anyway if you think $2/gal is here to stay than figure 45K miles for break even.
It appears from my reading that there is a lot of play in the 80 series drive train, so once the front is disconnected and the natural binding from full time 4wd is gone it seems to feel "loose" and the steering feels "sloppy" or "light". Also 80 series drivers seem to love full time 4wd. That seems to be the extent of the information on part time swaps.
I have to have the noob's back on this. I used the same search string he was advised to use and it did in fact return the fatal error. I tried the advanced search and it did the same. I even tried using quotes and searching in only the 80 specific forum but all three searches returned the fatal error mentioned by our chastised noob.
I also tried folowing the link. But it was also a dead end.
https://forum.ih8mud.com/search.php?searchid=1564651
Click this link. It returns nothing.
Advanced Search. (ALWAYS use this.)
Keyword(s): "part time"
Search Titles Only
80's Section
I do.
This helped eliminate the fatal error
Search Titles Only
This was the only search that did not return a fatal error.
80's Section
I generally do select to search only the 80 section to narrow the results.
These are all great pointers that might have helped the noob and even me about a year ago. There is still the issue of the error. Seems like the search tool should just dump you to the "no results found page" and not display a URL that is obviously a result of server error. If the returned results are too large I would think you would get a screen similar to the "no results found" where MUD links and search window are still active.
Here is the error:
Fatal error: Allowed memory size of 67108864 bytes exhausted (tried to allocate 1245048 bytes) in /home/forum/search.php on line 1016
At any rate hope these last posts help out a noob and dont get me in too much hot water.
:beer:
If you want cheep and some what easy, put in some hubs, pull the fornt drive shaft and install the center diff lock switch. Either do the pin 7 mod or pull the right plug at the back of the t-case. This will give you want you want. This will also give you the chance to see if this is what you want before you spend a alot more money on a kit that you may not want. Just put in the fornt drive line when you want full time. It only takes 15-20 min to pull or install the fornt d-line. Later robbie
He has a '92, hence he already has the CDL switch and has no pin 7. Pulling the propeller shaft could take a lot more than 20 minutes, though if you dicover that some of the studs are messed up or if the flanges are really rusty...
It should only take that amount of time if the truck is maintained. I have pulled a lot of drive shafts and have done this with my personal truck for the last 3 almost 4 years. I have not buggered or hurt any bolts, or studs. It is all in the mannor of how you treat stuff.
I did not noticed what 80 he was talking about in his post, but do see his sig line now. later robbie
I did the part time kit on my 45 project for a few reasons, but fuel economy and handling was not them. The truck does drive very similar to before, stops the same, and gets the same economy roughly. I did the conversion for front driveline issues that could easily be remedied with it and because I was planning to flat tow the truck. It turns out that it was not needed at all for the driveline issues and I don't tow the truck with all 4 down. I would still do the part time though because I like the idea of 2wd, and it does take the load off the Longs birfs. For most people it would be a waste of money.
Based on my experience, I would not go to part-time on an 80 that is used as a daily driver anywhere it snows. Much nicer handling stock and the gas saving was not significant. I assume that at a mile higher you see some snow, no?
I cringe a bit every time I see someone go part time. It seems to me that full time 4WD is one of the advantages of the 80's and it's a big compromise to go part time.
When people do this, do they pull the full time emblem off the back?
