Part questions?
Townsville, Australia
Hi. Can anyone plse tell me what the differences are with these "kangaroo spec" parts? The cleaner parts are from my 78 FJ40 2F, and the later spares from a later 80 something model.
PVC return pipe differences?
The next, any takers on this manifold sensor / switch?
The last two are difference between carbs?
Thanks!!!
Dirt is the only difference. Both are 61010 parts, so are the same or interchangeable.
edit: I thought you were asking about the manifolds. It appears you are concerned about the different vac fittings. don't be. They unscrew and can be noved as necessary.
The PCV fitting is barely visible in the middle photo. It's a 90 degree elbow threaded into the manifold beneath the carb.
The brake booster fitting is the one on top at the rear. The later ones are finned to dissipate heat so as not to cook the rubber hose.
The black vac fitting in front of the carb is a manifold vacuum source for the choke breaker.
