Part numbers for bushings
Hi guys,
can anybody lemme know in regards to the part numbers for an 80 series landcruiser 96 model, manual?HDJ81V. I need the following part numbers :
1. Radius arm and panhard rod complete set ( front and rear?)
2. Front stabilizer bushings. (bar size 29mm & bracket is 32mm)
3. Rear Stabilizer bushings and linkages(upper and lower) ( bar size 25mm& bracket is 32mm)
4. Trailing arm bushings (rear)
That should cover it. Or any other bushings that i need to change? Thanks for the input and help people.
Yudy
Yudy,
The above link might help if someone doesn't come back with your specific part numbers.
-B-
Thanks Beowulf for the link. Found most of the part numbers i need. Im replacing every single bush with polyurethane bushes. But i need to compare the prices between the original rubber bush and the poly ones. Will let yu guys know how much in price difference as a total.
Yudy :beer:
