Can you help me. Looking for 2 parts #'s that are very elusive.
Rocker arm piece and oil pump mount piece-----
On the Rocker arm, there is a plug on each end. The mechanic helping me on this rebuild called it a "welch" plug. basically a freeze plug on each end. I needed to clean inside the rod (toyota# 13901-61020) so we had to drill out the plug to get it out of the rod. Now i need to replace the plug but O'Reilly's doesn't have the correct size. any idea if this is a direct buy part from Toyota or do i just have to keep hunting for the correct size plug from another source?
Another one:
Oil Pump mounting block -- best I can tell, this is what it is called. the cylinder block breakdown doesn't have a part # beside it. What I am looking for is the bolt and washer that holds the mount block on. Actually only need the 2 washers. It is a metal washer with an embedded oil ring. can't tell from the picture and the description gives nothing other than *** STD. PART. is this the part I am looking for? toyota# 94712-91200 or # 91615-40820 . The mounting block is shown on the link below. beside this, the two part#'s there. but there is no number beside the block, or on the oil pump page.
http://www.toyodiy.com/parts/p_U_1987_TOYOTA_LAND+CRUISER_FJ60LG-KA_1105.html
again, I don't need the block, just the washers that are on the bolts that hold it on.
hope you can help. No prize or grade for this pop quiz, just a thank you!
Jeff
Another one:
Jeff
