Part Number Info Help Needed
Las Vegas, NV
Aloha,
I recently rebuilt my 97's passenger side knuckle, and two of the bolts holding the metal retainer for the felt seal, etc, broke off inside the knuckle housing when attempting to loosen. It's holding together for now with the remaining 4 bolts, but not only do I want to back drill out the broken ones, I just want to replace all these bolts from the back of both knuckles. I may postpone rebuilding the driver's side until I get these new bolts.
I have called the parts center of local and non-local dealerships, and they are just as confused as I because Toyota has changed the # for this part multiple times. Plus, I can't figure out the specs on the bolt to find an alternative replacement locally at a hardware shop. I need help determining the correct part number for this 10mm bolt, or need enough information to go to a local hardware store to get the next best thing.
The attached diagram (which came from Toyota) shows two part numbers and indicates in parenthesis that a total four of these bolts are needed. Whenever I type in the numbers indicated on the diagram, the part comes up as for the windshield wiper. They might be the same, but I can't tell and none of the guys at any of the parts departments I called were certain if this was truly the correct bolt. The guy at the dealer from the Lakeland, FL parts department (Authentic Toyota Parts | Toyota Parts Overstock - https://parts.lakelandtoyota.com/) came up with a different parts number, 90080-11231 but he was unsure as well.
Much appreciation and gratitude for the assistance.
If you weren't aware, here's another resource for you PartSouq Auto Parts Around the World - https://partsouq.com/en/catalog/genuine/unit?c=Toyota&ssd=%24%2AKwFlUUBuICwVITU1JCk4cz0pCQ4QYW5jYnBuXCx0JXJtdAtxIiJ_dWxjLSkjODdOez40PzVybWR9cWhpeHVsc2RvZmNxIiJ1OXRrcmNuYGY3Nz4qKCc5MxYqcW1jPm12c2duZ2BnPiIwd3Q4JHVscXFeQU4WG3N8d3Q8MCw6PHUQCxpvZhZ-SU5MEh1zfHd0JzAsOjw5Iz08e3ZzNWdkPm12ZC0AAAAARDGDbg%24&vid=0&cid=2&uid=342617&q=
I found it somewhat difficult trying to find parts/and part numbers at the beginning of my 80 ownership. Sometimes my research in this amazing forum/resource was confusing and convoluted with so much info, it became confusing to lock down the exact part I was looking for. Familiarize yourself with the abundant resources out there and it'll get easier as you go. the link above has the hardware you're looking for plus a lot more. Scan it and check it out for yourself.
