Part number help
LUGOFF, SC
Ignore the below, incorrect parts.
Why are there two Transmission Drain Plug Gaskets, with the same part number 35106A? and different prices?
Or more importantly, which one should I be ordering for a '97 with auto trans?
I need a new new drain plug and want to order the correct gasket.
The middle one on your list corresponds to what I ordered and installed on my 1994 transmission successfully. It also seemed correct for differential plugs - anything with 24mm drain bolt.
I suspect you have a different transmission, but perhaps the 24mm bolt had is the key. It is an aluminum crush washer.
So I have come to the realisation that the gaskets and plug listed above don't fit my transmission pan. My drain plug uses a 14mm wrench, same as the engine oil.
9043012031 - it is some sort of nylon, I got 4 of them on the same order.
That looks the correct gasket. Thank you.
