Part number help, front parking sensor for 2011 LX570
Barrington, IL
Hey everybody, just like the title says, I need a part number for the front parking sensor for my 2011 LX570. I have one that seems to have been damaged when moved over to my ARB bullbumper. It sounds all the time.
From what I can tell the part changed to 2013. There seems to be a 2pin sensor and a 6 pin sensor type.
It would be great to know the exact part number. There might even be a white and black version. I would need black.
Are there cheaper aftermarket ones that work as a drop in replacement also? Toyota vs Lexus? Appreciate any lead on a good price too.
Thanks!
There are colors, yes.
you can research the partnumbers on a site like lexuspartsnow or partsouq.
I tried to order one for the back sensors via the equivalent part numbers, and it had the right plug shape, but the plug orientation ridge had been moved on the sensor. The diameter of the sensor was a bit smaller as well. It's easy enough to shave down the orientation ridge, but I wasn't wild about the diameter difference, so back it went.
The OEM sensor are much $$$.
fixed. Took out the sensor, cleaned outside, cleaned contacts, replaced. All good.
Front sensors on a 2011 LX570 with 12/13/2010 build date are P/N: 89341-33160
They have 6 pins in the connector but only 3 wires leading in.
They look like this:
