Part number for these two hoses
California
Can anybody identify the part number for these two hoses mine are cracked need new ones. It's the 8 and 9 on the picture.
8. PCV valve and PCV hose #1
9. PCV hose #2
Glad you found it. Beno is always a good source for parts as well and knows landcruisers very well. I didn't have the part numbers so I couldn't help you there and just saw you post. I would be a good idea to change out the PCV valve and grommet as well when changing the hose if you haven't done so yet.
do I have to take off anything to install grommet and pcv valve?
No, its a real simple fix. Take the old hose off, gently pry the PCV valve out - be careful the old grommet doesn't fall apart and fall into the hole, and replace with the new. Takes a couple minutes is all. The FAQ has a section on it I believe.
Alright thanks
