Part identification (fzj)
Boone, nc
I"m looking into gettin an fzj 80 and when i was checking it out i noticed what looked like an idler/tensioner pulley that seemed to be seized. it was about halfway down the block and oriented on the right hand side(if you are looking at the engine). The only thing that was weird was that the belts were not touching this pulley, they were very close but not touching and the belts were still tight.
Can someone tell me if what i'm explaining is part of the pully system or if its something else thats not supposed to move.
P.S. i know its hard to figure this out with out pics but hopefully i explained it well enough...
On a FZJ80, that idler pulley on USDS belongs with the 2 alternator belts.
It should be snug. The tension to the belt is adjusted via the alternator, not the idler pulley.
Pics may show the problem better.
Very possible they misrouted the belts, or used the wrong type of belts.
ok sounds like the idler pulley then. And if that is not where the tension comes from i'll just let it go and fix it when i get it home.
Thanks for the replies, if anyone has any other opinions let me know.
