I bought this rig a few months ago and have been working on it every since (it had a box of parts that came with it). One of the projects was the front ARB bumper has parking lights and the wires were just hanging there. Well after I finally have "everything" done to my rig with no more parts laying around ready to install I figured this was my last job to complete the rig. I took out the parking lights below the headlights and checked which wire was lead and which was ground and hooked up the ARB lights to the parking lights. Incandesant bulbs do not matter any way but I wanted to make sure I was consistent with the existing parking light wiring.
When I turned on the parking lights I have none, not one out of four light up. I took all 4 bulbs out and jumped them with wire from the battery and all 4 work fine. I unplugged the connector coming from the wire harness and turned on the parking lights and hit it with my meter and I do not have any voltage. Now here is the stupid thing I did, I did not check to make sure the parking lights worked before I wired up the ARB.
I looked through my FSM manual (not the electrical I wish I had) and I can not find anything about parking light diagnosis or fuses anywhere. This is a 93 FZJ80 and I have the Slee upgrade harness with the Aux Harness as well. Everything works as it should incuding the tail lights when only the parking lights are on and the rear side marker lights are on, it is just the front parking lights that are not coming on. I can not think of anything the Slee harness would do to effect the parking lights and I have checked all my fuses. Any ideas or similar problems?
Again I said my first mistake was not knowing if these lights worked before I hooked them up but my real problem was not knowing what the lights were to begin with. They are NOT parking lights but blinkers. :whoops: When reading the mod with links to Slee's mod for the corner parking to flasher and all the links to other forums on this mod I went out and turned on my blinkers and these lights that I wired work fine.
