parking Brakes on disk conversion!
Hi guys,
this is my first post since i registerd about 5 min. ago.
I just bought a 1978 cruiser Fj 40 for about 1K US. the body is in poor shape but the rest is A1. it came with replacement fender( aluminium), hartop, softop, 2 tubs, 13 mag, and a hole lot more spare parts.
I was considering doing the swap for disk brake on the rear......but a question remains.....if any of you guys have done it....how did you manage the parking barkes?
comments would be very handfull since that this truck is my first big mechanical projects , car wise at least!
one more thing, i may do mistakes in my post, my first and native language is french!
A 78 had the e-brake on the rear output shaft of the transfer case. You can put whatever rear brakes you want on and it will not affect it. If you had a later cruiser with the p-brake in the drum, then you could go to the Caddilac Eldorado rear calipers rather than the popular Monte Carlo front ones.
Welcome newbie. :)
He might have a later model axle with the Pbrake on the ends (similar to a FJ60)
76 still should have a Pbrake on the tcase.
Have you looked under the truck at the rear Driveshaft?? What does the driveshaft hook up to? Is it a flange or is it a smallish brake drum looking thing?
If your pbrake is on the Driveshaft you have nothing to worry about when doing a rear disk conversion..
Double check and see if Disc brake kit you are using makes use of the typical GM brake caliper. Most likely its from 77- 85 Monte carlo. If so, look for the rear disc calipers from a 77-81 Cadilac. The calipers are the same fit and will have a parking brake lever on it. DO NOT ACTUATE THE LEVER IF YOU BUY THEM NEW, AND THEY ARE UNMOUNTED!!!!! This will make the assembly "POP out" and you will not be able to get it back together without damaging the seal. Ask me how I know this!!
thanks again guys. I will check on my cruiser in the next couple af days...........the cruiser is sitting in an old barn at my sister in law farm.....40 min drive from montreal!
If I do the conversion, I will manage my own kit...i have acess to a complete machine shop for brakets and stuff like that! plus one of my in laws is a manager for a napa store........I save big $$$ on most parts
