Parking Brake
Oklahoma
How does the parking brake work on a 75 40? I have four wheel disks and my oem parking brake has not worked since I bought it so I thought I would take the old brake lever out and figure something else out. When I was looking, I saw a cable that attached from the brake lever to the rear drive shaft mounting flange. I had always assumed that parking breaks worked on rear drums, but this made me think that it is something else. Was I looking at the wrong thing? I didn't have a lot of time to work, so I may have overlooked something. Any help would be appreciated.
Thanks,
Zac
Put simply, it is a drum brake attached to the rear output shaft of your Tcase. It is in the housing where your cable goes in. The drum for the brake is where the rear driveline attaches. As far as "removing the brake lever" I dont know what to tell you other than to ask why? Why not rebuild it if it doesnt work? If your rear seal leaks it gums up the shoes and thats not good for anyone. Maybe a set of Ebrake shoes, rear seal, and a speedy sleeve are in order. Not to much work to wind up with a good parking brake. Good Luck, Eric
second what bcon said
CCOT has a pretty cheap and good emergency brake kit that includes all that you need to tighten that thing up. There is also a good article the FAQ section here with pictures walking you through each step. I did mine in a couple of hours. Good luck
IIRC, Liquid Offroad sells a complete kit for $39. He also lists them on ebay, but I think the starting bid is $39 and ignorant asshats routinely bid the price up :doh:
Just a tip I have a 75 also and my e-brake didn't work I tried crawling under it to adjust with no results I was about to rebuild when one day I was taking out the underdash light and I realized that the cable connecting to the brake handle wasen't connected...I realized that it looks connected when it's pushed in and I had never pulled it and looked Thats what I get for assumeing....hehe....check the obvious first....
there's an adjuster on the back of the drum...iirc, it's counterclockwise to tighten, also, you can also adjust the cable at the firewall by shifting the two nuts on each side of the firewall.
Had the same problem as MAC but my ebrake was disconected at the lever in the drum itself. Just had to pull the rear axel and housing and reconect... 15min fix.
BTW my ebrake works great for foreward momentum but does basically nothing in reverse!!
Anybody know why, thought about putting in new pads but they still have good meat on em???? WTF
peace
neal
I just bought the disc ebrake set up from man-a-fre. seems nice enough. we machined out one section so I could put an extra seal in.
neal
rear axle? do you have a later model axle? your sig says 75. or did you mean rear driveshaft?
Drum brakes are designed to cam into the drum when depressed, they tighted themselves up. You dont get the same camming action when the rotation is reversed. Same issues w/ drum brakes when rolling backwards, not nearly as effective.
Thats what I have heard anyway.
