Parking Brake Gone Bad
Humboldt Nation
Parking Brake Gone Bad Turns into Bad Front Wheel Bearing (maybe more)
Parking brake was very thin when checked this last summer. Last weekend, after pulling this guy out of the drink at Clam Beach
and giving him a ride home to Trinidad a few miles up the hiway, I heard what I initially thought was the rear drive line making quite a bit of noise. Limped it to the gas station and took a look underneath. Didn't seem to be the drive line or the rear calipers so I slowly limped home. Noise didn't diminish when brakes applied and when parking and backing up into my spot, it made a bit of a screeching noise. Pretty sure it's the parking brake shoes come 'undone'.
Had yesterday off for Veterans and today but I've got the bug and don't quite feel up to it. If it'll stop raining for a bit, might try to pop off the wheel and rotor and see what has 'developed'.
There you go...
:cool:
Sounds like it's time to R&R your brakes. A call to cdan is probably in order.
Working on it. So far...
Slow start but not feeling tops right now. A little drippy outside also.
Onward.
There you go...:cool:
Well, got the rear brake caliper off and noticed...
yup, sand in the piston cup.
Still...had to use a bolt to push the rotor/drum off and low and behold...
all in tact. :confused:
So, it doesn't seem to be the rear parking brakes making the gosh awful noise still going on as I moved the cruiser to the driveway.
More pics HERE.
Not sure what else it might be. Ujoints, even though they appear to be intact?
Help me Mr. Wizzard.:crybaby:
:cool:
Could the sand be binding the caliper and preventing it from retracting all the way?
Ok. But man, it sounds like something is really loose and coming apart.
Brakes seemed to work just fine.
I'm going to slap it back together for now and see what happens.
:cool:
:cool:
Look for small rocks lodged between backing plate and rotor on both sides. I was wheeling one time and got a rock trapped in there and it made a hell of a noise. HTH
Thanks. No rocks found. Trying to reassemble but working on the driveway, not feeling well and lack of patience today isn't getting it done.:mad:
:cool:
Is your wheel bearing shot? I had one that crapped out on my 91 truck and would have sworn it was the e-brake.
Well now, I really don't know. I'll have to explore that.
I know I shouldn't, but I do a LOT of water crossings down at the beach. Not in the ocean, salt water and all, try to stay out of that. The creek is fresh water, but water non the less.
Thanks,
:cool:
When was the last time you checked the lube back there?
(Hmm, that doesn't sound right....)
I don't have it marked in my maint. log when I 'checked' it last, though I believe it was right before McGrew. The last time I changed it was 6-23-07 at 163,607 miles.
13,212 miles ago. And....I'll check it tomorrow. No leaks back there though.
What are you thinking?
:cool:
Nothing cheap if water got in there and it was making the sort of horrible sounds you say it was. :doh:
13k miles isn't that long....but if you do as many water crossing as you suggest, you should definitely step up the wheel bearing maintenance cycle.
Good point. I'll dip my finger today and see if I can tell what color the gear oil is.
Pray I don't find milk.:doh:
:cool:
OK, here we go. Parking brake in need of replacement but intact. Not the problem.
Rear diff gear oil good. Not the problem.
Removed rear drive line thinking bad u-joints. Engage 4x lo, drive, still have noise. U-joints not the problem.
Clunkity, clunk, clunk. Wife arrives home during this test and indicated noise isn't coming from the rear but in fact, OMG, the front.
I think I may have BBS. In a bad way.
So I'll park it in the drive way and as time allows, explore the possibilities up front.
This is going to be such an adventure. :mad:
:cool:
Similar problem, at least it fits under the same thread.
My rear axle/wheel was making a squeaking nice that increased and decrease as speed increased an decreased. Today after disassembling the rear brakes, the problem was finally solved. One of the pins that slides through the hold down spring and cup had straightened out. On the rear axle one pin is straight the other has a shape like __l---l__ (as close as I can get, I didn't take photos) The pin didn't bend completely straight but enough to no longer hold the shoe against the backing plate, causing a rubbing.
My rear parking brake was making noise and what happened was it had gotten too loose and the bellcrank had come loose. It made a sound like a chain dragging on the ground almost.
:cool:
Trying to understand here: did you fix whatever the problem was in the rear axle/hubs? Lots of water surface rust there Russ...I'd check the rear wheel bearings since you are pretty much there anyway.
Front now? Hmmm.....did you lock the CDL and pull the front drive shaft to at least isolate whether it is drive shaft related or axle/front end related?
Good luck dude. Rainy season is upon you all up on the NorthCoast as well...
-o-
x2
Good suggestion. :)
Here it's been more foggy than rainy lately. We've been getting "air stagnation" alerts, which is really weird for this time of year (and this long too). Oh well, means I don't have to worry about rain. :cheers:
Well, I'd relate the 'surface' rust to my many trips to the beach. Worst thing I see back there is the exhaust pipe.
I did not pull the rear axles (yet), but I did pull the rear drive line thinking it might be a bad u-joint. Not a bad rear u-joint.
Next opportunity I'll reinstall the rear DS and pop out the front and see what tender nugget of information that might yield.
Still thinking that 'bad front bearing' noise that's been developing will turn out to be a bad birf.
First things first, thanks for the direction.
There you go...
:cool:
