Parking brake discovery
Meant to post this way back in April, but got it back together with your help and its working great now . Thanks a ton to all posters.
Finishing up power steering now...
H
PS I let most of the gear oil prior to the pull, just got in a hurry ;)
The hub of the drum slides over the output spline and the oil seal runs on that, as soon as you pull the drum off the oil will escape.
It's probably best to drain the transfercase first :)
I will be working on my soon. So, first thing to do is pull the hub to open it up, right? Instant mess if gear oil isn't drained?
I ordered my brakes/seal and dust cap from JT Outfitters. It was a good deal and I called it into Joe and got way better priority shipping price than ordering online. He ordered some extra oem toyota dust boots $4.50 and mine was so gone..Well actually the hole was plugged with a mix of original rotted dust boot, ancient gear lube stirred in with
I just finished mine as well. didn't realize the bottom spring had to go in the back makes sense now I see it may restrict the cam. anyone use the dust cover in the back from sor? is an OEM one available from Toyota? View attachment 1240449 View attachment 1240450
decades of dirt. Yea, it's a good part to replace.
Yes, simply drain transfer gear lube, you will have stinkin' gear lube all over the floor if you don't
