Parking brake dash light switch location
East California
The parking brake dash light stays on about 90% of the time even though the handle is completely down. Anyone know where the switch that triggers this light is? I did do a parking brake rebuild a couple years back and haven't had any problems until now.
Thanks,
Patrick
That switch is under the lever. Pull the boot off and it is right there.
But that light also comes on when the brake fluid reservoir is low, which sometimes indicates that the pads are badly worn. Also comes on when the level sensor is failing.
If the fluid level is good and unplugging the sensor turns off the light, it is the sensor. You can get a new cap for the brake fluid reservoir with a sensor in it from the dealership.
It's amazing how many people DON'T know that the parking brake light also indicates low fluid (or worn pads). This is true for almost every car on the road.
Yep. News to me. It's understandable since the light says "park brake". No reason to think it has any connection to the main brake system.
Light is just the standard ISO symbol for brakes here in North America and Japan
Low brake fluid was the culprit. It is only a 1/4 inch lower than the MIN line. That sensor is right on. DOT 3 fluid right?
You should check your brake pads, and carefully look for fluid leaks.
Worn out pads or fluid leaks are the only cause for low brake fluid.
Yes, top up with any DOT3 or DOT4 brake fluid. Fancy fluids aren't any better than the regular fluids in our application. Clean fluid is better old fluid, any time.
In my '94 it just says "BRAKE"
My 97 says BRAKE and incidentally, its on.
After disconnecting the plug for the reservoir cap switch.............my light goes out...ugggg bad switch.
Time to contact Cdan or Sam for a new cap...
fwiw, my brake light went from intermittent to persistent, so i eyeballed the reservoir a little closer.
It's stained green (?!) although the fluid in it is not green so it's hard to make out. It was a hair below "min". I filled it to a hair below "max" with DOT 3 and all my brake light problems are gone.
Yes my brake pads seem to have plenty of meat on them. yes I'll keep an eye on the level.
fwiw my truck is still using the sensor on the reservoir, cap is just a cap.
