Parking Brake adjustment
Decatur, Ga
Ok, so this should not be hard, right?
I plan on adjusting the parking brake on Sunday morning, so on Saturday night, while sitting next to the grill alone with nothing to do, I pull out the Haynes, just out of curiosity, because I dont remember seeing an adjustable cable leading to one of the rear hubs, as I have seen on everyother type of vehicle that I have been under before. I look in the index to find the right pages.
I find it and it descibes adjusting the parking brake at one of the rear brake wheel hubs. Why would I do that, the parking brake cable does not lead there. So I go to the next page that the book references, and it looks like I might be able to adjust it where the cable goes into the transfer case, which makes more sense.
So, which is it? Do some FJ models have the parking brake adjustment on one of the rear brake hubs and mine is adjustable at the TC? And how adjustable is it? How much adjustment can I get buy adjusting the cable under the dash?
Thanks!
If you have t/case handbrake, the adjustment is a small 10mm hex behind the backing plate.
Chock it, jack up the back, and tighten until in binds, then loosen until not dragging.
You may also want to take up stretch in the cabble where it goes through the firewall, but the h/brake adjustment is done at the t/case
Why would I need to jack up the back, if the cable runs to the TC and not the rear wheel hubs? I cant just crawl under rig and make adjustment to the backing plate on the TC?
adjustment either means
a> no rear driveshaft, so you can spin the e-brake drum and feel when it binds...or
b> rear tires off the ground so you can spin the e-brake drum and feel when it binds...
however, you may have the brute strength to spin it/roll the truck while you are under there....
OOOOooooooohhhhhhhh!
In one part of the Haynes, page 166 I think, made it sound like the adjustment was at the rear wheel hub. Then on page 170-something, the adjust was on the tc. thanks for the clarification.
