Panhard bar comparison
Portland, OR
Well, I bent my rear panhard bar... :doh:
I know that there were some threads on here before about about what is available and what ends/bushings are best, but I needed to know which one I'm not going to bend! So here is a comparison:
MAF 4+
Rear- Rubber bushing/spherical rod end, 1 3/8" (1/4" wall) DOM $250
(Notes- You can get this with poly instead of rubber for $245)
Front- Rubber bushing/sherical rod end, modified stock bar $250
(Notes- You can get with poly instead of rubber for $245 and there is a $175 core charge.)
MAF
Rear- Poly bushings, 30mm solid bar stock $275
(Notes- Says that it's not recommend for "tall lifts".)
Front- Poly bushings, 30mm solid bar stock $285
Slee
Rear- Poly bushings, unknown material $205
(Notes- Looks to be the same as the MAF bar. You can request factory rubber bushings for an extra charge)
Front- Poly bushings, unknown material $215
Slee weld-in
Rear/Front- DIY weld in adjuster $105 each
(Notes- I think the DIY part is pretty self explanitory!)
SOR
Rear/Front- Poly bushings, unknown material $401 for both
(Notes- They say that there is enough threads for 6" of lift.)
Alright guys, I know that poly is bad, rubber is good and spherical is the cats meow... But which one am I least likely to bend?
You aren't going to bend any of them. At least you shouldn't. Aren't both of the MAF 4+ now solid rod?
The rest of the decision really relates to bushing preference. These bars are setup in a swingarm design, so articulation is mostly rotation in a panhard of this length. Needing a spherical joint for twist is a non issue for a standard range articulation suspension (like OME L shocks).
What a spherical does is provide a rigid mount so you only have one bushing. The less play in a panhard the better, especially with the unsprung weight increases of large MTs. The downside of a spherical is if they get noisy. I've had my rear MAF bar on for a year with zero noise, which I have to say surprises me with my in-depth experience with these type of joints. I just ordered the front last night (with rubber on the axle end). They can have my core - my stock rear is still hanging out in my garage (hey, why don't you buy mine and angle iron it :grinpimp:) and doesn't need a companion.
I went this route because I don't like poly suspension components as a general rule, it's a personal bias over many years of premature failure, and I tried, oh how I tried, to make nice and cheap poly work. I just have never had a poly suspension component stand up to the abuses of rock crawling. Is this an issue in an 80 series panhard with the limited twist required? I think probably not. But at some point I don't like reproving things to myself that I already learned at plenty of wallet pain.
Having said that, the latest in plastic offroad suspension parts is polyester, which I just installed in the form of Slee blue CC bushings, so perhaps it is better.
Bottom line: all this stuff is very beefy, you are unlikely to bend any of it, and your choice is mostly bushing preference. Unless you are planning on a long travel suspension, in which case I would get the MAF 4+ rear hands down. It can even be fine tune adjusted while mounted on the rig :cool:. Actually, for a rig that is largely trail biased where minimal potential NVH is not an issue, I would build a rod with spherical on both ends and not have bushings. I used to run a dual heim front end on my old XJ, and that is a great setup. I really had no NVH issues and that was a unibody.
Maybe you should just copy my rig and stop asking all these questions :flipoff2:
You aren't going to bend any of them. At least you shouldn't. Aren't both of the MAF now solid rod?
Not according to their website. And I already bent one... Remeber, I wheel harder than you!
The rest of the decision really relates to bushing preference. These bars are setup in a swingarm design, so articulation is mostly rotation in a panhard of this length. Needing a spherical joint for twist is a non issue for a standard range articulation suspension (like OME J shocks).
I realize how they work... but I'm not in the "Standard range Articulation" either. I'm not real worried about the bushings, I just put them in there so other people could cross referance them easier. OH, and it's OME L shocks... J's are the springs...
Can't wait to hear how you like the front one. As for your stocker, why don't you give it to me and I will do amazing things! It will never bend! :hillbilly:
Understandable, I don't like poly either, but I really don't like bending crap...
And if they made a panhard with a polyester bushing, I'd be interested.
But does it have enough threads for my lift? With it not being a solid bar, is it not as strong? Remember, I can bend anything!
Why would I want to copy a :princess:?!? :flipoff2:
My comments in bold!
Raise the axle end mount on your massive lift and buy the Slee. Didn't you know that Polyester is blue? You could have just looked in your closet :flipoff2:
Given your plans to slam down on rocks just behind the axle getting that thing out of the way is clearly the only solution :banana::banana:
In some degree of seriousness, a possible good answer is not having a panhard to bend. I am of course far too much of a :princess: for this sort of thing, but even still if you take a little peek at the frame you'll find that a sprung over leaf with a 3" shackle would be pretty close to flat at about a 6"-7" lift. And we know that a nice flat leaf sprung has a number of excellent properties without sacrificing flex. Maybe just add a little ole traction bar. Bye bye panhard, low hanging control arms, and swaybar. Shock mounts at axle height on that much lift for 12" travel.
Then with the rear providing balance, load bearing, and stability, you can 3-link the front without turning it into a slinky. Get the Slee high steer arms and raise the axle end of the panhard to match for no bumpsteer. The lower arms of the 3-link can be mounted at axle tube height to keep them out of the way.
Not bending stuff really isn't the issue. It's not having stuff constantly in the way to bend. Add a set of ProRock 60's and you're good to go.
If you are really gonna be bending 1/4" wall DOM that is mounted just behind the axle, it's time for all that junk to go :popcorn:
Another question for you... Are yours a solid bar for the rear? If not, what material is it. It's not listed on your site.
It's not a solid bar...I had one for awhile and thought it was causing some noise which is why I went MAF.
