- Joined
- Jul 17, 2011
- Threads
- 12
- Messages
- 101
Hello all, I've got a 94 LC that I bought about a month ago and got the crazy idea to paint it myself.
I was going to do a color change but after starting to tear the LC down I realized how much more work that would be and that it would also bug me that I would have the factory color in some areas under the hood and interior that I just couldn't get rid of. I've got the emerald green so I'm going to stick with it.
My question is, I'm just painting the outside, but what should I do with the seams around the doors? Should I tape them off so no paint bleeds in between? I'm not planning to paint anything inside, so I would prefer to not have to tape off the entire inside to paint the door jams.
I was told by the paint shop to tape off the inside and paint up to the first bend in the door but is that necessary? My main concern is I don't wan there to be a durability issue with the paint. It seems that all the other panel gaps will just have the paint on the end of the panel and won't be wrapped around, so I should do the same with the doors?
The other issue i'm trying to figure out is the rear hatch. Should I remove the lower and paint it off the car since it is overlapped by the upper, or can I spray the bottom then lower the top over the bottom and then spray the top?
Hope that all makes sense. Thanks in advance.
