PAIR Air Pipe Flange Leak
North Front Range, CO
My PAIR has a leak at the flange on the manifold.
It needs welding or brazing.
As its right on the maifold, will brazing work or should I have it welded?
If welded, what type of weld should it be?
As the exhaust pipe to manifold gasket was leaking too, I wounder if its from my fuel problem. A backfire from my rich air fuel problem could of blown out the gasket and flange.
I just got the same leak on my '94 with 235k miles. Is this a common occurance or just with guys named Kurt who own higher mileage '94s? Any problems with the weld? Going to take it to get welded tomorrow.
Kurt
