Painting M416..what to do about "pitting"
Dallas, Texas
Guys obviously, these old trailers have rust etc. I will be getting mine sandlblasted soon. The problem I foresee is I doubt the sandblasting will get rid of "pitting" in the surface of the metal. Is there any option after sandblasting, to get the trailer coated with a thick primer to to fill in the pitting...so it will look better after it's painted? Any suggestion on what to use to fill in these little crevaces in the bare metal...prior to painting??
airlaird
If the pitting is visible to the naked eye, then you will need to use a plastic filler to get a smooth finish. It would take a lot of primer to fill in anything more than a scuff in the metal. Don't be afraid of a little filler, just don't go crazy with it.
Rezarf <><
Mine only had pitting on the inside. I sandblasted, primed, painted, and you could still see a bit of pitting. It wasn't a big deal for me, I didn't plan on this as a restoration. A few years later I lined the inside of the trailer and that took care of the evidence.
Powder will cover some pitting but not all, if it is deeper than 1mm it is going to need filler to be smooth.
Just my .02, but hey, it is a trailer, I'd just paint it! :D
This is my plan, but I've only got minor surface rust, no pitting as of yet.
Try POR15 I used it on my M100 trailer
www.7slotgrills.com/m100project.html
The bed was rusty but in one piece/ I just painted the bed
with RustO Dark Olive
The back of my M100 was cut out when I got, it so I welded in a a CJ7 tailgate. I had to add pieces of steel on top to follow the lines of the trailer. Those are factory cables from a CJ7. I used
after market stainless steel hinges so they open everytime and won't rust up.
That's creative way to come up with tailgate part!
The back of my M416 was cutted and converted to tailgate. The heavy duty chain was welded to the tailgate for max support (hauled dirts) and it is covered with bike tube for rattle-free.
Cheers,
You can use "lab metal". Its similar to jb weld type stuff but its easier to put down and can be spread thin, just work fast. Best to do this when there is bare metal or primer only. I used this years ago for a rusted trunk. This stuff acts like metal and can be drilled and threaded etc.. I've used to to repair hubs where the wheel bearings spun. This stuff isn't cheap but better than plastic filler..
Where do you source your lab metal from? Does it come in quantities (and how much)?
I can get JBWeld, but only in small amounts and while it'd work for small areas not something I'd want to use for larger areas.
AirLaird, I think you would be surprised what using a hi-build urethane primer will do to fill in the pits. Any that do not fill can be spotted with lacquer putty.
GL
Ed
By the way,, I bought it much cheaper at the bearing store than the prices on the site,, the can was $18 I think and the solvent was $11 or something,, both for right around $30-33 tax and all.. was enough to do a very pitted up trunklid on a 67 cadillac..
