paging JayhawkCruiser
Here I am..
I was wondering how to attach two sliders with only two pcs of steel??? I will call you later this week and try to get them from you. I am headed to IL for most of the week and I won't be putting the sliders on until I decide what to do about my rockers, tire size/body lift and any fender cutting.
Thanks
Craig
PS...I had a BLAST!
That would be great! I am going to have a friend look at the rockers to see if he could cut them with his plasma cutter and save me the time with the grinder/cut off tool. I think that I am going to leave about 1/2" of the lip and then bend it back to make about a 1/4" smooth edge. Instead of trimming fenders, I think that I am going to add a little bit to these sliders, so they protect the entire area. They are about 8" or so too short right now. If I ever do a body lift, I will just re-set the sliders, but at this point I will probably go back with 33" tires (when I can afford them) and consider 35" next time. The other problem with 35's is that I need a set of 4.56 or 4.88 gears and I do not think that I can find a set that I can afford right now. I will get in touch with you later about the gift cerificate.
Thanks
Craig
785-218-9280 cell
