My 97 LandCruiser has been getting a P1780 park/neutral code
recently. Static testing by measuring the level at the ECU while
manipulating the shift lever suggested (at least to my untrained
eye) that the mechanical positioning is good, i.e., the switch
doesn't close until the lever is well away from drive and the drive
indicator has gone out.
To get a better idea of what was going on I attached a little
piezo buzzer between the NSW and IGSW terminals at the ECU
and drove around. I found that the buzzer sounds *weakly*
when I make a left turn under power. It is not at loud as when
I actually switch to neutral or park. I suppose that stress on
the chassis could be moving the switch, but it feels more like
a short. I was going to check the wiring between the ECU,
key switch, and neutral/park switch but it occurred to me
that because I have an RS3000 my stock wiring manual may
not reflect reality. (I was not provided with any wiring diagram
for the RS3000 and the samples I've found on the net do not
seem to correspond to what's there. Even the 97 installation
manual shows wires that do not exist.) Anybody know if the
RS3000 fiddles with the park/neutral switch wire to, say, disable
starting?
Thanks!
starting?
Thanks!
