Pulled a P0500 code on my '97 so I ordered a VSS from eBay to see if it would fix the issue. Most of the responses I got were either the VSS is bad or the gauge itself is bad. Got the new VSS in the mail this weekend and replaced the old one. Only took a couple minutes, but I had no change in speedometer (*still doesn't work) and still had the same code after clearing it and driving around the neighborhood.
I didn't toss the old one so I could test it and finally got around to it tonight. Attached 12v battery positive to terminal 1, battery negative to terminal 2, test lead negative to terminal 2, and test lead positive to terminal 3. Set it to 12v on my meter and spun the shaft per the FSM (page BE-34). The voltage is supposed to be anywhere between 0v and 11v, so I assume any voltage is good. Bounced around 0.5v - 2.8v depending on how fast I could spin the shaft.
Am I missing something? It seems like the old sensor is doing as it should, but could it be not enough voltage change per revolution? I'm going to assume I'll need to pull the speedometer at some point, but how do you test it once you remove it?
