P0330 1fzfe
The connector may just be off or broken off. That was the case with mine after doing the head gasket. Get a look at it and see. It’s easy to break.
Well that's actually why I replaced them, the femail end of the actual sensor broke off in the connector. I ended up having to cut the connector off and get the old piece out. I soldered it back on after I got the piece out. After the code I checked the solder joint and it was good, so I'm not aure
