- Joined
- Dec 11, 2003
- Threads
- 10
- Messages
- 180
[quote author=landtoy80 link=board=2;threadid=12909;start=msg120143#msg120143 date=1079123656]
Does it mater what the max pressure is? If max is 35 then it is too high but what about 85psi max?
[/quote]
You are right, you can use up to the max pressure of the tire, which in turn will give you the max load carrying capacity the tire is rated for, but you don't have to, if you are not carrying all that load.
My BFG's are rated for 3305 pounds @ 65psi cold, that means I have to use 65 psi if the gross weight of the truck was 13,220 pounds ( 3305x4).
If you are not carrying the max load , you don't have to use the max pressure. But you can if you want, the only thing that will happen is that you will be bouncing around all over the place.
reducing the pressure will give you a more comfortable ride without any safety concerns, however, I have not been able to find a chart that relates Tire pressure to load capacity at different levels and for most tires the best starting point is what the owners manual calls for pressure wise.
[/quote]
