- Joined
- Mar 16, 2003
- Threads
- 201
- Messages
- 615
I'm perplexed...79 FJ40 w/ OEM P/S previously been working fine. Took it out of the garage and let it idle in the driveway. A few minutes later I notice fluid under the vehicle. Investigate and discover it's P/S fluid. Open the hood and see fluid seeping out the top of the P/S resevoir cap. I don't believe it was overfilled when I serviced it. Any ideas? All system lines and connections show no evidence of leaking.
I did take a bit of fluid out, wiped things down and no more overflow. After a test drive of 20 minutes, I ended up adding some fluid, doing another test drive and no overflow noted. P/S system works well before and after.
I'm thinking intermittent blockage - impending pump failure?
Let me hear what you think...
Thanks!
Dave
Thanks!
Dave
