Oz Prado 5VZFE oil pan/sump gasket replacement
QLD, Australia
Hi all.
Looks like I need to replace the oil pan/sump gasket on my 1999 5VZFE powered Prado. Removed the front bash plate to have a look.....
Anyone done this or know how? There is a heck of a lot of frame/diff between me and that oil pan.
Your thoughts.
Cheers.
Hi all.
Your thoughts.
Cheers.
did you observe any leakage?
do you mean the 12101B GASKET(FOR OIL PAN DRAIN PLUG)?
ToyoDIY.com
needs to pay a little attention not to brake the head of the bolt if you force it a lot..you can use an extension bar with a socket or an air gun ...
good luck;)
If the Prado is IFS like other IFS 4x4's that I have seen you will have to drop the entire differential assembly to get the oil pan off IIRC. If it is a solid axle it seems like you could unload the suspension enough to get the pan off. Would be a good time to install a locker. Please forgive the off topic question but would you tell me what transmission and transfer case is behind your 5VZ-FE as I am not familiar with the Prado?
